I used a gearwrench worked great I did mine because it was leaking on my 86.5. Did you think about rebuilding it instead of replacing you just need a small cylinder hone and the kit. The rebuild kit is like 12 dollars thats what I did worked out just fine. But if anything I think the one on my JDM clip might work on a US version car so I got a practically new one.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
