if i remember correctly he said it had 200,000 miles on it, it may not be a bad thing if you have mechanical knowledge, and can do alot yourself, i mean lets look at it this way, most twin turbos go easily for over 20,000, now you found a non turbo for 12, and if you wanted to make it a twin turbo, you can get a jdm 2jz for 2500 with about 30 to 40 thousand miles on it, and i'm sure you'll need the ecu and all that. so it might not be a bad idea depending on what you want. You might be able to find the whole front clip, 2jz engine, transmission and wiring harness ecu for about 4500.
Personally if i had that kind of money to spend, i would buy it.
