They are called block testers, also known as a combustion leak tester. A combustion test kit can be found at your local NAPA, auto parts store. The part number is 700-1006. The price for this part is less than $50.00. Exhaust gases in your cooling system can suggest a head gasket leak, a cracked block, or a warped head.here you go found this in a yahoo search, hope this helps.
