Originally Posted by demon2supra
hey yall I just got my first supra whith the 7mgte and i have codes 24 31 42 and 52 and iknow that 52 is knock sensor and 42 is vehicle sped sensor and 24 is the intake air temp sensor but the hanyes book does not give location for shit and i need help finding locations
http://www.toyota-supra.info/forums/...ead.php?t=6577
^^^^^Link to knock sensor locations.
Code 31 is your Air Flow Meter(AFM).The Intake air temp sensor is intagrated into the MAF, located after your air filter, it has wiring going to it.
Your Mass air flow sensor is the screwed onto the metal housing you see in the pic. VVV
You will have to replace the air intake temp sensor and MAF as a whole, since their both integrated as one sensor.
{The MAF is not viewed in this pic.
Since you just got the car, I would reset the ecu to clear the codes and then run the car a while, and then do a diagnostic again and see what codes you get. The codes your getting may be old codes.
