Old 05-15-2007, 05:33 AM   #27
supradaddy0803
supradaddy0803's Avatar
What I was getting at is there is 2 TDC combustion and exhaust it is basic mechanics. so it is possible for it to lined up at TDC on the exhaust stroke the piston has to be up to remove the exhaust. But as I said it was worth a try it fixed my 86.5 N/A but like I told him I wasnt sure about a turbo. Because if you line up the 0 and the distributor is not lined up with the number 1 point then you are at the exhaust stroke. But seeing as the 7MGTE doesnt have a distributor I figured why not try it.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
