If you put the studs in right, you can put an allen wrench on them and pull them 1 at a time. You have to thread the nuts to the studs and drop them throught the washers. Put the washers in place first the place the nut on the stud.
You need a 3/8 drive and a deep well 14mm. If you don't have washers get them.
You will have to rotate the cams to get some of them to drop.
