Originally Posted by demon2supra
i found that my knock senors are bad and are being replaced in about 12 hours,with them being bad will that rob low end torque and horse power?
and also i have a faint low idle miss any ideas what that could be, and does anyone have a factory service manual in a pdf format?
You sure the sensors are bad? I just had a similar problem with ses "52" and I did the knock sensor rewire and all is perfect now.
What code is your car throwing?
-99 Z28 A4 6.7L "2006 LS1tech Calendar cover car"
408ci, Comp 244/248, Patriot Stage III LS6 heads, FAST 90mm Intake, NW 90mm TB, SVO 42lb'rs, Pacesetter LT's, ORY, 4L80e, Yank 3400, Motive 3.73's, Racetronix, TNT 200shot, Fikse FM10's
-2005 Silverado Crew Cab 5.3L (Towing), Silverbirch, Hooker Aero Chamber, blacked out windows, sittin on 22's
- Two 87 turbo'd/targa top'd supras (*Under Construction*)
