Originally Posted by Sway_NV
...But is 94,XXX miles too much to buying a Supra?...
Not if it's been well-maintained.
...Also, the main
Supra I am looking at, has a "PowerHouse Racing-Garrett hybrid 60mm single turbo" What can you all tell me about that turbo?...
It's pretty small. It'll probably only do about 550rwhp max, even on race fuel and high boost. This figure will be even lower if it's an auto (vs. 6spd).
...Some of the other mods it has are as follows:
- K&N filter on PHR bent mandrel intake.
- PHR fuel pulsation dampener bypass.
- HKS EVC (boost controller)
- Apexi Super AFC
- HKS Type 1 turbo timer
- PHR downpipe
- Greddy intercooler
- HKS Super Suquential Blow off Valve
- GReddy boost gauge.
How does that setup sound? Strong?...
Depends what you mean by strong. Again, if it's a 6spd, you're looking at about 550rwhp max on race fuel and high boost. Even if the turbo could do more than that, the oem fuel system (even with fpdb) can't safely exceed that figure.
...Reliable?...
If the installs were all done properly, then yes.
...And as far as rims, do 18x9 for the front, and 18x10 in the rear fit nicely?...
It's an okay combination, but it really blows my mind why people use this combo. The oem rims are 8" front and 9.5" rear - the rims on that Supra increased the front rim width (from oem size) by 1", but only increased the back rim's width (from oem size) by 1/2". This is total insanity when you consider that the REAR WHEEL DRIVE car's horsepower has been increased by about 66%!!! Again, that rim combo is okay, but really not optimal.
...And for a last question, Any opinions on the sound of a Apexi GT Spec Exhaust?...
If you really want my honest opinion, you should be worrying about how well the car was maintained and how well it performs, and not how it sounds. Just mho...
Good luck with the purchase, thanks for posting, and please keep us informed!
