Old 05-17-2007, 04:55 PM   #10
Supra_87_mk3
Supra_87_mk3's Avatar
Supra_87_mk3 is on a distinguished road
i hafto agree w/ everyone.. if you have an mk3 you need to know your shit or have the will to try b/c these cars are unlike any other car you will own and if you pay to have it fixed you are gunna get screwed.
now to add to your topic. being a body man you look for a few things.. but like what was already said anyone b4 you could have had it out and you wouldn't know...its a 20 yr old car it was out at one point.
1st paint chips on factory bolts
2nd loose or missing screws
3rd screws or bolts in wrong place.
4th screwdriver marks around the holes..
5th carpet folded over wrong.
anything out off place will let you know.
Supra_87_mk3 is offline   Reply With Quote
