well i found a small ground from the base of the coil pak plate that was broke since i have replaced but i still have a slight low idle miss and slight miss under boost can anyone point me in some direction?
Originally Posted by demon2supra
i found that my knock senors are bad and are being replaced in about 12 hours,with them being bad will that rob low end torque and horse power?
and also i have a faint low idle miss any ideas what that could be, and does anyone have a factory service manual in a pdf format?
