Thread: jdm engine
Old 05-19-2007, 01:59 AM   #6
IHateHacks
IHateHacks's Avatar
Yeah the oil pressure sending unit has a big grey rubber boot covering it with a 1 wire connector you really can't miss it, just take the accordian hose off and you will see it.
The temp gauge sending unit is on the water outlet housing (not the thermostat housing) and is the bottom most sensor with a 1 wire connector. Take off the power steering reservoir and mounting bracket and you will see it. Its below the green 2 wire connector for the EFI ECT (Engine Coolant Temperature sensor for the ECU).
You have to replace these if you want your stock US gauges to work.
