The OEM rad is a pretty good unit. However, if you've got to replace it going with something with better cooling, higher capacity and less weight is always a plus. Especially since the price isn't much more.
If you just want to stick with the stocker you could always rebuild it.... that's right it's rebuildable. Look in the TSRM and EPC for info.
EDIT: IIRC, the fluidyne drops right in.
