N20 and HeAd WoRk
i have been in the middle of a head gasket swap for a couple weeks due to money and parts probs but i just got a lil padding back in the acount so...
i have my head off and its going to be decked and hot tanked... if i do head work what do you think i should get done... prolly a valve grind, port polish? im by no means loaded so i would like it cheap but im not settling for shitty( i know good head work isnt cheap but i mean afordable). i would also like some info on Nitro. bc i have the option to get a dry system really cheap and i wonder how harmful it would be? i know dry is alot safer than wet which is why i would go that rt.
any info would help i've been reading but thats never enough.
info on my car,
this is kinda Redundant but i have a
Hallman MBC,
ARP head Studs
MLS head Gasket (so compression should be at 8-1)
Upper Strut mount
Coil overs,
intake,
strait exhoust until i get it moving again
HKS FCD
i run Synthetic High RPM oil
NGK plat Plugs and wires
and i woul love the lexus afm
and walbro Pump and injecters.
