Thread: coolant temps
Old 06-11-2005, 02:14 PM   #1
ddmcse
ddmcse's Avatar
can we get some sample temps on some of your cars ?
i don't have an issue i just want to see ohter people running temps
running at about 190 degrees when doing 80 miles an hour on the highway the outside temp was around 80 maybe just shy of 80 but hummidity was on the high side
on the way back using a different route i traveled at about 45-55 or so temp was about 170 degree outside dropped to prolly 60's
about a 3 hr run total there and back
i can see the changes on the autometer temp gauge but on the stock gauge it doesn't move at all .
i start not enjoying the ride ( if or once) i get over 190 degrees ,
it's paranoid huh ?
what do you get ?
i have an electronic temp sensor into the block by # 6
i use a fluidyne radiator ,
a `16" electric fan from permacool i think it's 2900 cfm or so
last season i used straight water and redlines' waterwetter
this year i'm starting out with eco friendly green stuff ,, but i will prolly switch back to the water wetter
what are your running temps ?
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
