Ok I fugured out the initial problem but now have a new one. I didnt think I needed the turbo pressure sensors but now I have them on there and the motor acts a lot better. But now it has a low RPM miss like it is running rich and also black smoke coming from the tail pipe only when you rev it. Not sure if my TPS is off or what and not sure the procedure for adjusting it. If not that I am not sure all of the injectors are working good and the only thing that is different than the original setup in the clip is that I havent got my new inter cooler and just have the boost straight piped from one side to the other. I have been around a lot of turbo cars but never owned one so this is all new to me a little.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
