Old 05-24-2007, 01:10 PM   #5
supradaddy0803
supradaddy0803's Avatar
It is the speedo cable pig tail they always break. I have replaced one on my 86.5 and my 87 when I got them they cost like 11 bucks from the dealer. If you want the part number I can get it for you . I guarentee when you pull it from the tranny it will be broke at the tranny end. It is such a tight bend and if they get a little moisture in them they break like nobodys business. just remember to lube the other end when you change it out.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
