Originally Posted by dcrusupra
 Thats a lot of money to fix valve cover gaskets.
Get these, call toyota and get the valve cover gaskets and do that yourself. It's not hard. Just remember where all the vacuum hoses go.
The belts arent that hard either. Just get the correct sizes and replace them. Everything should be around $150 if you do it yourself. Belts are probably gonna be $25-30 (3 of them) each, i think the gaskets are $20 each, and those bolts are $32.
Now keep in mind i've never done anything like this before. I have changed oil and spark plugs and flushed the radiator and changed lightbulbs, but no engine work like this. If I have the supra manual and some elbow grease I should be able to do it? I don't need another person or anything?
Any word on the risks I run right now?
