Old 05-24-2007, 07:13 PM   #1
dannydavi
dannydavi's Avatar
I'm not saying i'm the one doing it right but i did the bleeding while the car was on for some reason, i would tighten the bleeder screw, have a buddy pump the pedal until it got hard, release the screw.. watch air and fluid come out while he held the pedal to the floor i tightened it back up. then repeated the process till no air was coming out. then did the other lines. everything seemed to work fine after that. also tried a brake bleeding vacuum tool that worked out, i dunno if any of this helps. good luck, hope you get it.
'86.5 Supra - A/T - N/A - JDM
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
