Picture would help a bit. If you have a n/a then there are like three that come off the throttle body two go to this vacuum valve thing and then one goes to the charcole canister via a VSV on the thermostat housing. But as for the turbo I am not sure I usually label everything when I take it off because it helps me locate where it goes back to.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
