Old 05-25-2007, 01:13 AM   #73
supradaddy0803
supradaddy0803's Avatar
That thing is like a vacuum filter. As for that screw that came out of the fuel pressure regulator or the thing at the end of the fuel rail. That screw is what releases the pressure at the fuel rail so if it is gone then you arent building up any fuel pressure. As for the vacuum lines on your turbo I have a 1JZ the vacuum routing is a little different. Just listen for a hissing around that area and that is were your leak is or spray brake cleaner around on your vacuum lines and if the idle gets better that line has a leak. As for the vacuum filter it doesnt connect to anything just hangs there. Lastly as for throwing it out the window the car weighs like 3400 pounds kinda hard to throw and push and stop.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
