Those beck/arnely wires will work ok, as you are N/A. I've been using Carquest wires for 3 years without a single problem.
I did go down to the speed shop and got some bulk MSD wire and ends for the coil to dist. I did this because the coil wire carries 6X the flow volume of current than each individual wire.
