Old 06-12-2005, 10:29 PM   #3
pabrosmc
pabrosmc is on a distinguished road
Originally posted by mrnickleye@Jun 10 2005, 03:36 AM
Has anyone out there installed an MSD Ignition Box on their MKiii N/A???
I hooked one up 2 years ago. I had to use an adaptor for the Tach/injectors to function properly. It works by making the plugs fire 15x instead of once on each power stroke. It will insure that ALL the fuel is burned. I could not tell any improvement, but I did see my MPG increase by 4 on long trips (26 mpg).
I removed it after 1 year because the tach needle would jump around occasionally. I emailed back and forth with the manufacturer trying to figure a way to get it solved. No success.
Any comments??
dont put it back
msd is garbage
i put one on a mk3 turbo
and no success eithier
pabrosmc is offline   Reply With Quote
