checked the timing, the left cam is almost on mark, the right cam is off from what looks like 2 degrees, and the main crank is reading 10. if i remember right it should be on 12, it was idleing at 670-700rpm's and i shorted t and e1 like the tsrm says to. do you think this is bad enough to cause this much of an issue. because im driving about 12-15 miles and used 1/4 of a tank of gas.
i also checked the egr valve, the filters looked fine, the tsrm said there is only 2 filters in there, but i had 2 flat ones and a thing that looked like a cotton ball. then i pulled off the line going to the intake and it felt like it was blowing on my finger when i gave it throttle, the other line didnt do anything, but when i pulled both off and blew through the intake side i didnt feel any air going through.
7MGTE - 500hp  never dyno'd
fidenza cam gears
