Nice try but "nope." The plastic piece that is attached to the back wall has a hole in the lip through which the latch part of the hatch passes. Even after I removed the 7 screws I couldn't move the plastic out of the way to gain access to the latch mechanism itself without breaking the plastic. I even removed the two things that are mounted behind the rear seats to give myself enough clearance to pull it out through the inside. Even with those out the top is about 3/4" too wide to pass through.
