When I go to clean the gasket material off the block how do I keep it from going into the holes in the block and the piston chamber. I know you can put rags in them but that isnt going to keep all the crap from getting in there. Also if you clean the piston heads (im going to) whats the best sovlent to use or can I just wipe it off (i have never worked on a head or pistons before).
