Originally Posted by mattfurlani
uh well you have to shave the valve seat in three seperate angles. I think it is 31/46/60 and i cna't particularly remembver if you need to take everything apart but just imagine remmoving your head from your car.
That's how much work it is.
so fdor a supra its romving intake, cooling system, exhaust, and many things like egr, vsv's, and a buncha other things i can't ermember.
almost everything but the block. a good 10 hours of labor with the right tools and know how
then its like $200 to havfe it angles done at a machine shop... a good priced shop at that.
yea and lets not forget you should pull your block out and have it decked while your at it. Its only an extra day of labor. You mine as well spend 500 at a machine shop and have them port, polish, and do a valve job.
-868 Miles on new jasper engine
-All hard pipes
-0.57 trim ct-26
-greddy type S
-greddy profec b
-apexi ride high 7 way adjustables
-eibach springs
-slotted rotors
-mkIV TT rims (front)245/45/17 (rear)285/40/17
-targa
-greddy turbo timer
-egr eliminated
-3" turbo back, no cat, no resonator, Apexi N1 back.
-n/a cams
Theres others ill think of later.
