Originally Posted by ssaskiksubucni
if both of you accually read, you see that he said he changed the motor relay AND he knows how to put the lights up manually. Check the motors and check all wire connections. pop up lights are very tempermental and need to be messed with.
If you would have paid attention in grade school, you would realize the correct spelling is actually and not accually, I guess that is backwood PA's way of spelling words (lol).
I know there are two relays associated with the headlights in 84 supras. One is the headlight relay and the other is the retract control relay (which is found under the dash, near the steering column).
I suspect if he replaced the retract control relay where I told him he could find it, his response back would have been, "I changed that relay out" instead of him saying to me,
"Thanks alot man! I'll check that today".
See if your stare and wiggle test work for the headlights.
