front coil spring...
i got a 89 supra n/a... and its automatic...
i got the supra from my nephew...
the car got a nissan z rims on it...
its a 16" rims...
with 225 55r60 front and rear....
last month... i cut the front top spring like 2.5 or 3"...
i install and everything work out ok..
i drive the car for about 3 weeks later...
the front left tire is srcatch the bottom of the car...
so thats my problem...
is it that i drop the front too low or is it my bearing worn out or wat is it...
60% sure that i needing new wheel bearing...
the front shocks are new... 2weeks old...
last couple days... i went to the pick and pull and get myself a new front set of the coil spring... and cut the same like the one i cut before...
and i put it on... and it still does the same...
it still eat up the uder fender... it only does that when i turn to the right...
and its only does that on the driver side only...
the right side is ok...it didnt eat out my under fender...
so anyone with any suggestion..... that will help...
can anyone help me...
