Old 06-02-2007, 04:55 AM   #10
Agreed, use some good moly to lube all the moving parts. Nothing's worse than a dry start. Simply pouring motor oil over the cams doesn't do nearly as good of a job as lubing all the bearings, cam lobes and seals, valves and so on with a proper assembly lubricant.
