Thread: stupid auto
Old 06-03-2007, 04:27 PM   #1
bigdoggbmx
bigdoggbmx's Avatar
bigdoggbmx is on a distinguished road
Exclamation stupid auto
hay well just got done rebuilding my motor and got it all put back togather
and now i can not get the knock code to turn off this is code 52
all i done to the car was port and polish new gaskets all around and
cooler pipeing. intake. (bov no this is not causing the knock sensor)becouse it was on there when i got the car and all the hoses
on the cooler pipe are new no leaks checked vacume all good and also new
is it possible that my timeing is not rite i set the cams at top dead center
and also the crank pully at top dead center on 0 on compression stroke put the pin in the diog box
pinched vac line and set crank position were i left it i re wired the knock sensors a wile ago so i do not know what to do i know that it is possible that the knock sensors could be bad but i realy do not want to spend $150 each
and not know what one is bad .....is there a way that i could make the car think that the sensor is there and take it off with out buying a stand alone or
a piggy back computer couse if there is let me know
so if any one can help me please
thanks
bigdoggbmx is offline   Reply With Quote
