cut springs and tems
so i was just wondering if you where to cut the spings by maby a coil, would the tems unit go all wacky on you like keep going from sport to super sport or whatever the 3rd stage is all the time. or would just keep working like normal?
7MGTE - 500hp  never dyno'd
fidenza cam gears
