Originally Posted by sks
I would also add that proper cooling modifications will be required if one has a FMIC - power steering cooler and oil cooler, the former being the most imperative.
With respect to methanol, how long can you run it on the track before it runs out?
10-30 laps Depending on the PSI im running (the higher the psi the more i use)
Jasin K
