Old 06-08-2007, 09:53 PM   #6
f00g00
Get a compression tester and remove one spark plug at a time, screw in the tester and crank the motor till the guage max's out, with the coil wire off of course.
Not really hard just a little time consuming doing all 6 then putting the intake back together. You will need to remove it to get to the middle plugs.
