starting problems
well one day when i hooked up my air fuel ration gauge my car ran fine for the first day then the next day when i went to start m car agin it wouldnt start so i was searching for an hour until finally i came across that the efi fuse blew so i replaced that and unhooked the air fuel ration gauge cause i had a feeling that that was the culprit of the whole problem and now since then whenever i go to start my car after it has sat for like overnight it takes the car forever to start up it sits there and tries o turn over for at least 8-12 seconds before it actually starts but then after that i am able to actually start it up all day with no problems unless it sits over night
has anyone ever heard this happening or has it happened to you if so input would be greatly appreciated so i can try to figure out my problem i have here thanks
