Old 06-10-2007, 01:18 PM   #4
IHateHacks
IHateHacks's Avatar
I would replace the sending unit. Its only $20 from the dealer. Use a 17mm closed end wrench to remove it so you don't have to remove the power steering reservoir.
The sensor is actually on the water outlet housing, not the thermostat housing.
