code 51
alright so i've been recently having an issue with my custom intercoller pipes and they keep popping apart, couldnt seem to get the clams to tighten up enough. so i just ordered 3 J-bolt clams "spring loaded" to try out. but thought i would mention that it has came off about 25 times now. care just goes putt putt putt blahhhhh.  and then i do a quick temp fix to hold it back together. my BOV "HKS SSQV" is in need of serious attention the spring is cut and its needing to be greased every week. i just ordered a greddy type RS bov so i should have that problem fixed soon. but now that pipe has came off today and now when at idle my CEL flashes a code 51. switch condition signal. what you all think i should look for and test out?
7MGTE - 500hp  never dyno'd
fidenza cam gears
