Thread: 2jz question
Old 06-15-2007, 02:19 AM   #2
supramacist
supramacist's Avatar
Man....., if you don't know wich motor is wich you probably have no need to even be thinking about swapping. Your' screen name should be: "Reckless Endangerment".
The 2j series engine will not just plug and play. Unless you go twin turbo the 2jzgte is the hot rod.
You may just be better off to re-build your JDM. If you can pull that off you'll have 1 7m build under your belt. I can't even say I have that but it's getting close.
