ok or not, mmm btw the idle is very low and the air/fuel gauge "my inaccurate one" is going all over the place. up and down when under load it is ideal almost lean then i let off the gas and then sometimes it will goto rich. at idle the check engine light will either flash the code or just continously flash. and then the after doing load then going to idle the rpms will kinda pop around a little like go from 900 rpms then pop down to 650 somtimes 600. then about 3-5secs after that the CEL will just start flashing away, but again the light will go away when it is on load
7MGTE - 500hp  never dyno'd
fidenza cam gears
