ok so we tested the terminals with the ohm meter. we even tested it with it off the TB. and we were getting readings. then we adjusted it and we tryed it all the way clockwise and the idle went up but when you hit the throttle the rpms would dive down about 100-200 rpms then go up and the motor would die. when it was all the was counter clockwise it get great throttle response but low idle, and was less prominent to the motor shutting off. i even switched off the TPS with the other one i have and it did the same things. i dont know what is going on with this thing but its going all weird. oh and when it dives down after giveing it throttle there is a little puff of smoke that comes out the muffler. but after every shift its having to recover itself.
oh and the CEL is still flashing at idle 2 flashes per sec.
7MGTE - 500hp  never dyno'd
fidenza cam gears
