Actually ive never heard of the GM MAF before you mentioned it.Found a few on ebay.This is what youre talking about right?
http://cgi.ebay.com/ebaymotors/gm-maf-3-5in-dsm-eclipse-mass-air-flow-meter_W0QQcmdZViewItemQQcategoryZ33557QQihZ014QQit emZ330135684452QQrdZ1QQsspagenameZWDVW#ebayphotoho sting
or
http://cgi.ebay.com/ebaymotors/3-5-GM-MAF-ported-HI-FLOW-LT1-LS1-DSM-4G63T-refurb_W0QQcmdZViewItemQQcategoryZ33557QQihZ018QQi temZ280124006449QQrdZ1QQsspagenameZWDVW
As for boost control i got a blitz solenoid controller installed already
Is there any specific features you would get with the maft pro speed/density setup compared to just using my blitz to controll the boost?
As for other mods,heres a list so you know what i got:
-Reworked botton end w/ Wiseco std size pistons,Eagle rods(not here until august so will use std rods for now),Arp and clevite33 all around,Toga oil pump
-Ported and polished head (being done as we speak) w/ std cams
-Cometic 2.0mm steel head gasket
-A1000 fuel pres regulator
-Walbro 255
-680cc low imp injectors from fiveomotorsport..not sure what make these are as i havent recieved em yet.Anyway quality was garanteed
-AEM Wideband controller w/ 02 sensor
-Other gauges like fuel pressure,boost etc
-RPS stage 3 clutch - 6 puck w/ new bearing kit
-Greddy timing belt
-3" Custom stainless steel exhaust
-Blitz solenoid dual stage boost controller
And lots of other bits and pieces that dont really apply to the engine build
and probably a few that i forgot to mention
