Sounds liek a alram issue then but usually they have a starter cut off and they just wont turn over but from all the stuff you describing it sounds like that alarm is crapped out. I would find the alarm control box and diconnect it and then try to start it. They usually put them under the dash so that would be the first place to check.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
