You said your getting a reading? What reading exactly?
The low idle can be compensated for by the idle screw at the base of the stop throttle body. Look at page 101 of the TSRM 07_FI and it shows you exactly where it is. Set your base idle with this screw to what ever you want and then you can fine tune it with the dashpot adjustment. You will still need to make sure your IDL switch is closed at idle and adjust your TPS with the feeler guage after the idle is set to whatever you prefer.
If the light still flashes the 51 code even after clearing the codes by pulling the fuse and the IDL switch is set properly then I would suggest reading the wires from the ECU to everything that you can. You can probably do this in about a half hout to an hour and it gets you familiar with your cars electrical system.
