also see if you're headlights are aimed correctly. One could be aimed higher or lower than the other. Drive up to a wall of some sort when it's dark out (garage door works well), park about 15 to 20 feet away, and look at where the beam concentrates at for each headlight. If it's about the same distance up from the ground, then they're pretty well aligned.
