well i passed my emissions down here, i was really suprised to. but it can be quite all that matters for sound is the choice on your muffler. if you get one that has a silencer on it you will sound almost as quite as stock but with a little meaner tone to it. mine sounds loud because its a straight through with no silencer i have a video of mine with it was 3inch DP and then at the DP it went to 2.5inch and to a straight through muffler with a silencer built into it. and it was pretty quite
7MGTE - 500hp  never dyno'd
fidenza cam gears
