There is so many things you can do to a persons car I have done most of them. If it has a distributor take off the cap and take a pencil and draw a line from one point to the next all the way around makes it run like crap. Watermellon rinds under the drive wheels. Corn cob in the tailpipe. Drop of water in the coil runs like crap untill you replace it. Reverse power steering lines. Marbles in the gas tank or a ball bearing these defeat the filter screen on the pump drives mechanics crazy. Or even unscrew his oilfilter one half turn just till it leaks takes a while but major engine damage. Also you can take the valve core out of his tires they will never hold air till he gets new ones. Now as for the legality of all of these supramacist is right it is kinda chicken s$$t but if you confront him without seeing him doing it then he can just deny it. Also on base dont get caught messing with someones car you will get arrested.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
