Hey whats up got your message sent you another one.. When you say it takes a long time to get up in RPM.. Does it do it at a stand still in park also..Does it sound kinda like its missing but its not, like the exhaust sounds subdued or muddy not crisp and clean.. If so its got either a blown head gasket or a cracked head..If so dont drive it.. if it blowes out completly and you get water in the oil and the mains youll ruin them..I did that to my last motor.. Thats why im waiting on a metal head gasket.. My new engine had a cracked head, got a new one and now its time for the gasket..Could also be a vacume leak start the car and spray starting fluid around the intake ducting to see if it idles up if it does theres your leak.. Your timing belt could be worn out and has skipped a tooth or 2 causing the timing of the cams to be off.. Pull the cover and put the crank at 0 TDC and see if the timing marks on the cam gears line up with the marks on the backing plate(little half circles cut out on the top inside) Let me know how these thing check out and ill give you a few more to check..
