Thread: power steering
Old 06-22-2007, 02:33 AM   #2
supradaddy0803
supradaddy0803's Avatar
Well a good way to tell is the banjo fitting ones are uaually pressure and the ones with spring clamps on them are return. If it is on te rack itself the top one is the return and the bottom is the pressure. I hope that helps. Also the hoses pass under the car from one side to the other because of the location of the pump to the steering box. Just follow them back to the pump from the top and bottom one on the rack and you will find out which one it is.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
