Yes but it's a p.i.t.a. .
You have to find the drain plug on the tank and drain it.
Then you can drop the tank.
You have to remove the fuel pump from the tank.
You have to open the gas cap. You have to losen it so it can drop the spout from the fill up location.
You have two bands. With 2 guide pins and cotter pins in the end.
Drop those bands. But before that get a jack with a nice 2 x4 ond apply pressure. Then drop the bands. Then you can lower the jack and get up into the back and remove a few lines.
You have to undo some wiring inside the trunk. A circular cap on the passenger side. Remove it and undo the connectors. Before you even mess with the tank. Sorry but you'll get it when you see what I'm saying.
Once you dis-connect the fuel lines going up under the body. You can drop the tank and they are smaller bolts like 8.mm I think.
When the tank is out open all the caps on the top and pull the float. You may as well wire in the walbro while you do this as well. Replace the float.
Get it from the dealer.
Reverse all of that once you figure the order out. I hope this helps.
