As far as I know the 7m with a R154 has the same clutch setup. I know you can use the clutch but not the flywheel if that makes any sense. At least this is what I have read from another forum.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
