Old 06-23-2007, 09:12 AM   #2
carfanatic89
carfanatic89's Avatar
carfanatic89 is on a distinguished road
The only thing i can think of is bad gas, but make sure that the fuel pump is working and that all the grounds are good and not rusted at all. check the fuel filter for cloggs. An engine needs 3 things to run fuel, air, and a spark. Check all of those. You could have popped a fuse to the fuel pump. A check you can do is turn the key and have someone listen over at the gas tank cap, take it off and see if when you turn the key see if the fuel pump comes on for a couple of seconds in order to build pressure in the system for starting. Try this and see what happens. Hope this helps
carfanatic89 is offline   Reply With Quote
